Wrong wiring between Line and Neutral
Discussion in 'General Electronics Chat' started by MMew Mamew, Jan 28, 2016.
  1. MMew Mamew
    Jan 28, 2016
    Dear All,
    1. Could you please explain me, if the cable is wrong wiring between Line and Neutral (3 Phase-System)
    and we use this cable for charging any equipment (such as welding machine and milling machine)?
    2. Refer to question no.1, ELCB or RCD can protect current leakage or not, and human who use this cable will get electric shock or not ?
    Thank you.
  2. Externet
    Nov 29, 2005
    775
    57
    Welcome.
    Start by not expecting everyone knows what you mean by ELCB and RCD. Express properly too.
  3. Dodgydave
    Jun 22, 2012
    5,143
    768
    What cable?
    Elcb and Rcd are earth leaking detection devices.
  4. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    If you have a grounded neutral 3ph system then the use of a GFI, ELCB or RCD will be a protection for any grounbd faults on the equipment, if this was your question.
    Max.
  5. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,844
    1,309
    Do you mean that neutral and one of the phases are exchanged?
    MaxHeadRoom likes this.
  6. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    In the majority of cases the supply of whatever nature is often further conditioned by a transformer in a welder or CNC machine.
    However, if there were single phase fusing on the input to the machine, it could be that the neutral ends up being fused instead of the live conductor.
    Max.
