Wrong figure & equation in Magnetic units of measurement
Discussion in 'Feedback and Suggestions' started by jonahugh, Oct 30, 2012.
  1. jonahugh
    Oct 23, 2012
    In the section on
    I noticed that there is an illustration relating to capacitance and equation for dielectric calculations. This is just underneath SI units.
    Although there may be some specific reason for this, I am a little confused by it, since the sentence after the illustration refers to "micro" which is not included in the illustration.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    In wich chapter of the eBook is this error?
    Can you give us the page?
    Bertus
  3. jonahugh
    Oct 23, 2012
    Hello Bertus,
    This is in Volume 1, Chapter 14.
    Thanks,
    jonahugh
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  5. tshuck
    Oct 18, 2012
    3,531
    675
    I believe I am going to have to side with jonahugh on this one.
    You are correct that this is a diagram pertaining to a capacitor, however, it has no place in the chapter titled, "Magnetic units of measurement", considering it pertains to the electric field as opposed to the magnetic field.
    Additionally, the following sentence references a μ that has not been defined, or even seen!
    I believe this is a case of simply uploading the wrong image....
    Also, the image can be seen again(and rightfully so) in Volume 5, chapter 1, page 5.
  6. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    This is a link to the correct image:
    http://openbookproject.net/electricCircuits/DC/10233.png
    Note that the image number at openbook project (ibiblio.org) is the same as the number of the incorrect image at AAC
    This is related to me re-using some not available image numbers. There were several images affected. I cleared it up at ibiblio some time ago. At least, I think I cleared it up at ibiblio.
    To fix this jrap or somebody needs to download the above image from ibiblio to aac.
    Considering that there were several bad images when I fixed it at ibiblio, reloading all the images might be warranted.
    This might be the only way to get the images that we have made changes to recently-- unrelated to this thread
    Dennis crunkilton.
