Writing to the flash memory of PIC18f87J90
Discussion in 'Embedded Systems and Microcontrollers' started by RG23, Oct 26, 2011.
  1. RG23
    Thread Starter Active Member
    Dec 6, 2010
    301
    I want to write the contents of count304 to memory location 4104 of pic18f87J90
    I implemented the following code but did not work
    movlw 0x00
    movwf TBLPTRU
    movlw 0x41
    movwf TBLPTRH
    movlw 0x04
    movwf TBLPTRL
    movf count304,0
    movwf TABLAT
    TBLWT*+
    bsf EECON1, WPROG
    bsf EECON1, WREN ;enable write
    MOVLW 0x55 ;WRITE
    MOVWF EECON2
    MOVLW 0xAA ;WRITE
    MOVWF EECON2
    BSF EECON1,WR ;set WR bit to begin write
    BTFSC EECON1,WR ;WAIT FOR
    goto $-1 ;WRITE TO FINISH
    bcf EECON1, WPROG
    BCF EECON1, WREN ;DISABLE WRITES
    If anyone has an idea please let me know
  2. joeyd999
    Jun 6, 2011
    2,759
    2,943
    You're sequence looks correct...though I am not sure if a two-byte write works with only one byte written. The datasheet is not clear on this. Try TBLWT two consecutive values prior to committing to flash.
