Writing multiplexers in Verilog
Discussion in 'Programmer's Corner' started by stupidlogic, Sep 2, 2010.
  1. stupidlogic
    Aug 10, 2010
    39
    I am going through some basic labs using Verilog using the Altera DE2 board with the Cyclone II chip.
    I need to make an eight-bit wide 2-to-1 multiplexer.
    The information that is given is:
    There is a select input s and when s = 0 the mux's output m is equal to input x, and if s = 1 the output is equal to y.
    The truth table for the circuit is:
    s | m
    0 | x
    1 | y
    It can be described by the following statement:
    assign m = (~s & x)|(s & y)
    As I mentioned before I have to use this to write a Verilog module that has eight assignment statements like the one above. The circuit has two 8-bit inputs X and Y and produces an 8-bit output, M.
    I have to make specific pin assignments so I can download it into the FPGA chip. They are:
    -SW 17 will be the input switch s
    -SW 0,1,2,3,4,5,6,7 will be the X input
    -SW 8,9,10,11,12,13,14,15 will be the Y input
    -The SW switches will be connected to the red lights LEDR
    -Connect output M to the green lights LEDG 0,1,2,3,4,5,6,7
    I think that is all the pertinent information. Below is what I have so far:
    Code ( (Unknown Language)):
    1. module lab01 (m,s,x,y);
    2.
    3.     input s;
    4.
    5.     input [7:0] x, y;
    6.
    7.     output [7:0] m;
    8.
    9.
    10.
    11.     assign m = (~s&x)|(s&y)
    12.
    13. endmodule
    I know it's far off, but it's what I got so far. Any help would be appreciated. Even a link to some tutorials on basic Verilog.
