Writing data to SD card using PIC18f26k80 over SPI
Sangam Singh
Joined Jun 23, 2015
9
I am using a PIC18F26K80 and an XC8 compiler. I am trying to initialise an SD card and create a file. I have simply formatted the SD card on Windows to have a "FAT32" file system and an "Allocation unit size" of 512 bytes. The capacity of the SD card is 2GB. I am using the MDD library from the MLA Legacy version. My main is the following:
Code:
FSFILE * file;
char sendBuffer[22] = "This is test string 1";
// main function
int main()
    initIO();
    LATBbits.LATB0 = 0;
    // Initialise SPI and SD-card
    while ( !MDD_MediaDetect() );
    // Initialize the device
    while ( !FSInit() );
    // Initialize
#ifdef ALLOW_WRITES
    // Create a new file
    file = FSfopenpgm ( "FILE.TXT", "w" );
    if ( file == NULL )
        while(1);
    // Write 21 1-byte objects from sendBuffer into the file
    if ( FSfwrite ( (void *) sendBuffer, 1, 21, file ) != 21 )
        while(1);
    // Close the file
    if ( FSfclose ( file ) )
        while(1);
#endif
    LATBbits.LATB0 = 1;         //LED
    while(1) {}
    return (0);
The program gets stuck inside the function "FSInit()" and the error I get from the function is "CE_BAD_PARTITION", which means "The boot record is bad".
The "initIO()" function is the following:
Code:
// void initIO( void );
// Sets the pins on the PIC to input or output and determines the speed of the
// internal oscilaltor
// input: none
// return: none
void initIO()
    OSCCON = 0x75;                  // Clock speed = 32MHz (4x8Mhz)
    TRISA = 0;
    TRISB = 0;
    TRISC = 0;
    TRISBbits.TRISB0 = 0;           //LED
    TRISCbits.TRISC3 = 0;           // set SCL pin as output
    TRISCbits.TRISC4 = 1;           // set RC4 pin as input
    TRISCbits.TRISC5 = 0;
    TRISAbits.TRISA5 = 0;
The last two bytes of sector 0 are the boot signature and they are meant to be 0x55 and 0xAA and the picture I included confirms that. However, inside the function "LoadMBR" the following check is made:
Code:
if((Partition->Signature0 != FAT_GOOD_SIGN_0) || (Partition->Signature1 != FAT_GOOD_SIGN_1))
    FSerrno = CE_BAD_PARTITION;
    error = CE_BAD_PARTITION;
else
and although the bytes are the same the first condition is met and it returns with the "CE_BAD_PARTITION" error.
I also downloaded the SD card formatter and used it to erase all the sections that normal format doesn't. However, I am still getting the same error. I have attached a zip file with the code. Could someone please have a look at it. I can't figure out what is wrong.
