Writing a microprocessor program
Discussion in 'Homework Help' started by sdonke002, Apr 2, 2011.
  1. sdonke002
    Oct 12, 2010
    18
    I am stuck on a homework problem. I need to write a program that will add any 2 digit bcd number located in memory locations 6100 & 6101. The results need to be placed in the x register and displayed on the terminal.
    This is what I have so far. Please let me know what you think.
    MVI C,00
    LDAA 6100
    MOV B,A
    LDAA 6101
    ADD B
    JNC
    INR C
    (JNC here)STA 6102
    MOV A,C
    STA 6103
    MOV X,A
    JSR FFBB
    BRA to this location to stop program
    If anyone has any input it will be welcome. Thank you!
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Which microprocessor is this program written for?
    Also, since you are adding BCD numbers, isn't it reasonable for the result to be BCD?
    If so, why don't you check the result (temporarily A) if it is longer than 9, and instead you check if it is longer than 15?
  3. sdonke002
    Oct 12, 2010
    18
    This program is written for the MM68HC11 microprocessor. I will work on doing the hex to BCD conversion and post it when I am finished.
    Thank you
  4. sdonke002
    Oct 12, 2010
    18
    Ok. I rewrote the program and I think it should work.
    Here it is:
    LDAA $6100
    ADDA $6101
    DAA
    STAA $6200
    LDX $6200
    JSR FFBB
    BRA (to this location to stop program)
    I have walked myself through the program in my head and it seams to work. Any ideas?
    Thank you!!
