writing a interrupt program in 89c51
Discussion in 'Programmer's Corner' started by Abby, Jan 20, 2008.
  1. Abby
    Jan 20, 2008
    i want to write a program to handle an external interrupt at int0
    for tht i must write a program a location 0013h
    how can i do this
    i using keil for programming
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
  3. saha
    Jun 1, 2006
    53
    check this file a simple program copy and paste in keil save as .asm file add file to project . You should get it.
    regards,
    saha
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You should look in the compiler documentation for an "interrupt" keyword. This keyword will allow you to select which vector to use and more importantly tell the compiler to use an RETI instruction to return rather than the usual retrurn instruction.
    This is one of those "extensions" to the C language whose implementation is definitely non-standard. Whadya gonna do! -- Eh? Fageddaboudit!
  5. jvjtech
    Member
    Jan 26, 2008
    23
    It has been a while since I worked with Keil tools. I took a look at the example suggested by Nanovate and see the "interrupt 0" qualifier on the ISR. I assume that the file REGS52.h maps this ISR to location 0013h as mentioned by Abby. A good source of reference information is the sample code available on the Keil and Atmel websites but one has to be aware of tool (compiler/assembler) specific twists. Regards.
