Say what? You can write anything you want into a text file. If you want to use it for some useful purpose or with a particular software package you need to supply a bit more information. Helps us out here; we are not mind readers contrary to popular expectations.
in ngspice, I want to write the calculated voltages and currents, in different txt files, one for each voltage step. I use dc sweep, e.g. I run for 0 to 500 V with a voltage step of 1V and I want to have at the end 501 txt files, including all voltages and currents for each timestep. does this make sense?
