Ok, anyone have suggestions on reflowing a chip the size of a the letter "E" on the esc button on a keyboard??? Same process, something different? I usually use a heat gun... I'm going to have to get a magnifying glass or something!!!
Yes. Magnifying glass(es) are very handy when doing small SMD parts!
And so is very bright lighting.
I solder a lot of 0402 components and those head magnifiers are great I also use a led light focused on the spot being worked on. I also like Solder Paste which makes life easier. You can reflow one end of the component but solder the other end. I have found that trying to reflow both ends One end sits up and I end up with a component sticking up at 30Deg. or so. I also solder wick up the solder at one end of the Track.Ok, anyone have suggestions on reflowing a chip the size of a the letter "E" on the esc button on a keyboard??? Same process, something different? I usually use a heat gun... I'm going to have to get a magnifying glass or something!!!
by Robert Keim
by Aaron Carman
by Jake Hertz
by Aaron Carman
