Would this creation a vacuum suction?
Discussion in 'The Projects Forum' started by stanman11, Oct 12, 2011.
  1. stanman11
    Nov 23, 2010
    230
    I'm trying to achieve a vacuum by sending air through the green tube, (in to out) sucking in air from the in/out blue tube. pulling the piston back to the end
    Would this T valve work?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Are you trying to create a sort of Venturi effect?
    http://en.wikipedia.org/wiki/Venturi_effect
    Venturis work well for low pressures, but you'd need a lot of airflow to drop the pressure very much.
    And where does a piston fit into this? I don't see anything resembling a piston?
  3. stanman11
    Nov 23, 2010
    230
    I guess a venturi is exactly what im trying to do.
    The piston would be attached at the in/out port
  4. #12
    Nov 30, 2010
    16,703
    7,339
    It's entirely possible, but the shape of the tubes affects the results. I have one of these that I bought for making a suction filter from tap water flow. I believe you need a nozzel so the air flow is introduced at smaller diameter than the tube it is blowing past. A tiny bit of googling would probably clear up this point.
  5. stanman11
    Nov 23, 2010
    230
    would this help increase the suction?
  6. #12
    Nov 30, 2010
    16,703
    7,339
    I think the injector tube is too long. Try making it adjustable! and get rid of the interfering shape on the end of the air exit tube.
