Would these be good speakers / mics
Discussion in 'General Electronics Chat' started by vindicate, Aug 20, 2009.
  1. vindicate
    Thread Starter Active Member
    Jul 9, 2009
    158
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    They are not good, they are horrible.
    The mic produces no bass frequencies and no high audio frequencies.
    The tiny speakers do not have any spec's. Since they are tiny then they will not produce any bass frequencies and maybe not produce any mid-range frequencies. Who knows if the produce any high audio frequencies? Their max output level will be very low.
  3. vindicate
    Jul 9, 2009
    158
    I guess I should rephrase my question. Would these be any decent for testing purposes. If not are there any on the goldmine electronics website that would be better?
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Vindicate, you started 2 different threads, both immediately link to goldmine electronics and its products. Are you trying to spam the forum?
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    Is it called Spamming when somebody posts links to garbage parts that have no spec's?
  6. vindicate
    Jul 9, 2009
    158
    Do you honestly think I'm spamming? If you search for my past posts you will see that none of my other posts have to do with goldmine.
    Only reason I have started these threads is because I plan on placing an order with them, and I had a few questions on which would be the best to get. As in I don't want people to say "Digikey has this part", because I want to make 1 order from 1 place.
    So sorry to ask a simple question. Not everyone can call themselves the "Audioguru"
  7. bertus
    Administrator
    Apr 5, 2008
    15,804
    2,389
    What will be the application?
    Do you need hifi or can the specs be lower?
    Greetings,
    Bertus
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    I answered the question, "Would these be good speakers / mics?" and explained why not.
    They would probably make a little noise. The question did not ask about making a little noise.
  9. vindicate
    Jul 9, 2009
    158
    Thanks Bertus for the helpful reply.
    They don't have to special at all. All I want is to do some experimenting. Maybe try some amplification from the mic to the speakers. Simple stuff. Not something that is going to stay in a finished project.
    Right, and I asked for some suggestions for something better. I didn't say I didn't believe you.
  10. bertus
    Administrator
    Apr 5, 2008
    15,804
    2,389
  11. vindicate
    Jul 9, 2009
    158
    Can those little PC speakers reproduce voice? All I've ever heard them do is beeps :p
  12. bertus
    Administrator
    Apr 5, 2008
    15,804
    2,389
    Those PC speakers have a limited frequency range.
    There will be hardly any basses.
    They are also used in very cheap transistor radio's.
    Greetings,
    Bertus
  13. Audioguru
    Dec 20, 2007
    9,411
    896
    The Goldmine does not say spec's for anything.
    But I think those very cheap parts will make a voice sound awful.
    My pc speakers are 3" in diameter (very small for a full-range speaker) and they have a pretty big magnet. They sound pretty good. They look something like this:
  14. flat5
    Nov 13, 2008
    403
    17
  15. going_in_deep
    Member
    Jul 25, 2009
    12
    hiii vincent ,
    the pic's u displayed from gold mine are of less output power , so what i insist is those work good for voice's as output . anyway those can also be used for testing to.. :)
