An op amp differential amplifier as shown is built using four
identical resistors, each having a tolerance of ± 5 %. Calculate the worst possible
CMRR.
It's given at 5%. For each of four resistors you choose either +5% or -5% and you see which combinations produce the worst result. It seems intuitive that all four resistors at exactly the nominal value produces the best result.
won't cmrr be the least (worst) when the differential gain is less, and common mode gain is most. simply apply the appropraite min/max resistance values to the dc and ac analysis formulaes.
