When you say paralleling, you mean paralleling the modules or paralleling the chips inside the modules? Or both? The things I have read seem to indicate that paralleling IGBTs becomes exponentially more complicated for each device in parallel above 2 in parallel. This is because they have a negative temperature coefficient and whichever one gets hotter faster will hog the bulk of the load and get even hotter even faster. Thermal runaway. I believe this is the reason for the modules; the chips inside are matched and balanced, thermally linked, to prevent thermal runaway. But I would assume that when you start putting the modules in parallel, you run into the same problem again. So it would make sense for the modules to be made in even larger sizes, into the tens of kilo-amps and above? But then as more chips are piled into closer proximity, the more problems you have removing the heat, so maybe that's why we can't find any >4700A? Maybe for very high power applications, a mondo MOSFET module would be better?As far as making bigger ones - like I stated previously I am sure they have been built in the lab, but for any practical application the use of industrial modules and paralleling them is the way to go, because of the cost to develop anything bigger for the low quantity ( as in one piece for a lab ) - get to be prohibitive, and is typically much less reliable.
Wow! It is really, really big and it is water cooled as well.
Unfortunately, it just looks like a transistor. It doesn't act like one.Wow! It is really, really big and it is water cooled as well.
Thread starter | Similar threads | Forum | Replies | Date |
The world's most interesting tool | General Science, Physics & Math | 2 | ||
C | Scavenging SRAM for world's worst video card | General Electronics Chat | 0 | |
World's Greatest Cover Band | Off-Topic | 4 | ||
World's smallest computer from IBM | Off-Topic | 5 | ||
J | Desmay World's thinnest iPhone case? | Off-Topic | 8 |
