Workstation too hot
Discussion in 'Computing and Networks' started by FBorges22, Dec 23, 2011.
  1. FBorges22
    Thread Starter Senior Member
    Sep 11, 2008
    108
    Greetings,
    Today I am facing an issue that the weather is a little hot and dry and I noticed that my workstation CPU fan is spinning at ~5000RPM.
    My workstating are not showing any problems beside the noisy fan. But, I am a little concerned about this problem and I took this screenshot showing how the internal temperatures are behaving in my case.
    Are my temperatures too hot to be safe to use the workstation?
    Thanks,
    FBorges22
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Did you check if there is dust in the fan and the heatsink of the CPU?
    Dust can block the airflow and have the temperature rising.
    Also look for the spots where fresh air can enter the case and leave the heat.
    Bertus
  3. FBorges22
    Sep 11, 2008
    108
    Hello, I just checked for dust and other types of air obstruction and I found none of these. Do you think that these temperatures are too high?
    Thanks,
    FBorges22
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    In the motherboard manual, there should be a section about enviromental conditions.
    Please take a look to see if you are on the safe side.
    Also placing an extra case fan will help to increase the airflow.
    Bertus
  5. FBorges22
    Sep 11, 2008
    108
    I checked the manual and it did not show the temperature limits. The fact that machine isnt restarting, hanging I belive that the temperature limits has not been reached yet.
    I also heard from my reseller that the limit maybe something next to 75C
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Can you look for the brand and type of the used motherboard?
    Also the used CPU is in concern with the temperature.
    Bertus
  7. FBorges22
    Sep 11, 2008
    108
    I am using a ASUS M4A78T-E with a AMD Athlon II 620 Quad core running at 2.6GHz
  8. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  9. FBorges22
    Sep 11, 2008
    108
    I am using the default AMD fan that was supplied with the processor.
    EDIT: As the night comes, the air temperature dropped in my room and the temperature in CPU dropped and the noise in the cooler has reduced a lot. I think the problem may be solved..
  10. thatoneguy
    Feb 19, 2009
    6,357
    718
    Those temps all look good to me.
    I don't worry until anything hits about 140 °F, which is still "safe", 180 F is the danger line.
    I have extra fans on the hard drives to keep them below 100 degrees, since heat is what makes them die early. Well, heat is what makes most all electronics die early, but the oil in the sintered bearings of the drive goes dry faster at higher temps.
    You shouldn't be concerned, unless your room temp was 40 degrees or something. (mines around 70). Download speedfan, it's a free program that will warn you when anything is too hot, and you can set the alert temp.
  11. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I found better quality of Intel than AMD either its performance or sound..
  12. Georacer
    Nov 25, 2009
    5,151
    1,266
    The temperatures seem textbook to me. Where you live I would expect much more. I wouldn't worry until my cores and HDD hit 45oC.
  13. FBorges22
    Sep 11, 2008
    108
    One interesting thing I noticed is that the Seagate´s harddisks tends to get more hot than Sansung´s hardisks...
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    Most everything has been covered, including the desirability of extra cooling.
    There is one thing you need to be aware of always, if you blow air (either shop or canned) through a heatsink there is a very good chance it will burn out. A high speed moving fan (moved by air) will generate voltage and burn out the fans electronics.
    If you decide to blow out heatsinks with a fan find some way to prevent the blades from spinning.
  15. @android
    Member
    Dec 15, 2011
    178
    9
    I use the amd+asus cpu. Their must be some utility in your motherboard cd called 'Asus FanX' or 'EPU'. Just install it. It automatically regulates fan speed depending upon the cpu usage.
  16. @android
    Member
    Dec 15, 2011
    178
    9
    I disagree! Intel has a legacy in the field of processor manufacturing no doubt(how can you doubt 'Gordon Moore' & Robert Noyce'). But if you set one price point and if you compare processors available around that point, you'll find AMD is a price competent than intel. It offers better clock speeds & features than intel.
