working with surface mount components
Discussion in 'General Electronics Chat' started by optionfa, Nov 26, 2009.
  1. optionfa
    Nov 2, 2009
    15
    Hey all,
    I am building a circuit that requires the following IC. http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=IR21362SPBFCT-ND
    The problem is I am in the development stage and I need to do some breadboard testing, now this IC is only available in surface mount configuration.
    I would like to hook it up and test it.. I don't want to solder wires to the pins as I am worried about damaging the internals. Are there any sockets available for these 28pin DIP surface mount chips? Everything I have found is for through hole components.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. optionfa
    Nov 2, 2009
    15
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I suggest that you use one IC for the prototype, and another for the finished part, particularly if you're going to reflow the PCB in an oven.
    Odd as it may sound, SMT parts will absorb moisture once the package has been opened. If you try to reflow them in an oven after they've been sitting around for a while, you might blow the lids off of them.
  5. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    in troubleshooting, or designing circuits of the SMT variety, your going to be soldering on leads for test purposes. I will glue the device to a teflon surface and tack leads on to run to a perf board. Remember that even with the most care, your first pcb will possibly have errors. With that in mind, I usually fab design circuits in sections, etch and mount the boards, then hardwire them together. I find this approach great for hammering out those last unseen obsticles, before cutting the final boards.
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
