Working out electrical characteristics of a device based on battery
Discussion in 'General Electronics Chat' started by Gump, Nov 25, 2011.
  1. Gump
    Jun 7, 2010
    57
    I have a small mp3 player, but I know nothing about its electrical properties, other than the battery. The battery has the following specs:
    So, I know the player uses 3.7V, but I can't work out the current it draws. I could work out the maximum current it could draw (assuming that the player is designed not to draw more than the battery) from the following line:
    Max. operating current: 1C (110mA)
    Although I don't fully understand it, is this saying that the device in theory wouldn't pull more than 110mA, but I'm not understanding the 1C?
    Thanks for your help.
    Gump.
  2. crutschow
    Mar 14, 2008
    13,518
    3,386
    1C is the battery current to discharge the battery in 1 hour. It is slightly less then the 120mA the Rated capacity would indicate due to battery inefficiencies.
    If you know how long the player runs before the battery is discharged you can calculate the average current draw by dividing the battery Rated capacity by the number of hours. For example if it were 5 hours then the average current draw is 120mAh/5 = 24mA.
    Gump likes this.
  3. Gump
    Jun 7, 2010
    57
    Hi crutschow,
    Thanks for the comment, hope you don't mind me clarifying... So, what that's saying is I can pull 110mA and in 1 hour I would have discharged the battery? As for how long the device actually runs I don't have a clue. It's an OEM make and the chinese importer (got it from ebay) website says < 10 hours... Not too detailed, but on the other hand, it won't be drawing more than a couple of hundred milliamps so that'll let me accomodate other components accordingly.
    Thanks,
    G.
  4. Smoke_Maker
    Sep 24, 2007
    126
    15
    You could measure it with a multimeter, do you have one yet??, or can you use someones else's???
    If you don't have one yet it maybe time to get one, it's indispensable.
    Gump likes this.
  5. K7GUH
    Member
    Jan 28, 2011
    191
    23
    By all means, get a multimeter. You can get a cheap one for about $3.00 these days. They go up in size and price from there. If you'd like to pay the postage, I have a good large one I'll give you. It will fit into a medium flat rate box, which is less than $11.00.
    Gump likes this.
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Close to a CR 2032 coin cell.
    But the dimensions put it at at CR2330
    That is a 235mAH cell, the replacement, anyway.
    CR(Dia)(Height in x.x form) So a 2032 is 20mm diameter, and 3.2mm thick
    Rated capacity discharge is 200uA, 5mAmax, 15mA pulse
    Gump likes this.
