By delay loop definitely does mean a delay in the program. What else could it mean??For PICs there is the 'delay' function which causes a delay with a duration which depends on a number you put it.
By delay loop doesn't means a delay?
With emphasis on "if it is also used in the main body of the program".For example if you have a program that uses interrupts, you can't use the C delay function in the interrupt routine if it is also used in the main body of the program.
by Jake Hertz
by Jake Hertz
by Duane Benson
by Jake Hertz
