Working of digital multimeter
Discussion in 'General Electronics Chat' started by guru200773, May 17, 2010.
  1. guru200773
    Apr 26, 2010
    94
    does any one know how a typical digital multimeter works i.e how it detects the voltage,current, continuity and how these detected signals r converted into digital signals to drive the LCD display....? thank u in advance...
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Try the DVM circuit at the link - http://electronics-diy.com/ICL7107_volt_meter.php
    Poke around a bit and you will find an ammeter circuit. Google will explain about reading resistance. Use "icl7107" as a search term to obtain the data sheet for the IC to see how it works.
  3. guru200773
    Apr 26, 2010
    94
    thank u friend...
