working of a p channel mosfet
Discussion in 'General Electronics Chat' started by sharath_412, May 15, 2008.
  1. sharath_412
    Thread Starter Active Member
    May 7, 2007
    32
    Recently i was testing the functionality of a P channel mosfet.
    1. I applied 3.3V to the source, varied the gate voltage from 0 to 5V. Till the gate voltage is 2.5 or 2.8 Mosfet was ON (I have put a resistor from drain to GND and checked the voltage across it)..
    Inference:
    Vgs<0 then it will be ON
    Vgs>=0 then it will be OFF.
    2. Now I applied 3.3V to Drain, varied gate voltage from 0 to 8V(I have put a resistor from source to GND and checked the voltage across it). The Mosfet was ON even if fthe gate voltage is more than 3.3V. How is this?
    Did i do any mistake?
    Please explain it to me.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    P-channel enh MOSFETS should be connected with the source to a positive potential voltage, load between the drain and a more negative potential.
    When Vgs=0, the MOSFET will be off.
    When Vgs is around -10, the MOSFET will be ON.
    Some logic level MOSFETS need a much smaller Vgs.
    If Vgs is somewhere between 0 and -10, the MOSFET will be in a partially conducting state. They are sometimes used this way in linear-type amplifiers. However, they dissipate a lot of power when used this way.
    In your step 2, you connected the MOSFET backwards. They do not work correctly if you connect them up incorrectly.
    With a P-channel MOSFET, you want the source to always be more positive than the drain.
    With an N-channel MOSFET, you want the source to always be more negative than the drain.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    In a pure MOSFET the source and drain are interchangeable entities are are defined only by the circuit configuration which dictates the source and drain. This is for both n- and p-channel MOSFETs.
    You need to consider the threshold voltage of the transistor which describes the volatge at which the source-drain channel begins to conduct current. The MOSFET will turn ON when:
    Vgs < Vth - both values will be negative
    For pMOSFETs it is often better to consider the voltages as their magnitudes (i.e. ignore positive/negative), this way the pMOS equations are the same as for nMOS. Therefore, the pMOSFET is ON when:
    |Vgs| > |Vth|
    From your above measurements the FET turns off when the gate voltage gets to ~2.8V. Therefore the threshold voltage will be 3.3V (the magnitude of the voltage on the source) - 2.8V = 0.5V. The transistor will turn ON and OFF around this voltage (as an actual voltage it will turn off when Vgs = -0.5V).
    Given what I said at the start about the interchangeability of the source and drain, this is exactly the same configuration as your first configuration.
    Did you increase the gate voltage from 0 to 8V or 0 to -8V. If increased it from 0 to 8V then the magnitude of Vgs (3.3V to 11.3V) will always be greater than the threshold voltage Vth, therefore by virtue of the ON state being when |Vgs| > |Vth| the transistor won't turn off.
    If you "increased" from 0 to -8V then there is an issue and we need to investigate further.
    Dave
