Working model of elevator
Discussion in 'Homework Help' started by Devrockzz, Nov 6, 2011.
  1. Devrockzz
    Nov 6, 2011
    Sir i need to know the software and the programming structure for building a model elevator for an engineering project at school. I want to build it as three levels (ground, middle and top) . :(
  2. John P
    Oct 14, 2008
    1,638
    225
    You'd better get started learning it then!
    Seriously, this is not the way to start asking for help. What have you done so far? People want to respond to your ideas, not just do your work for you.
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    Have you got the logic diagram written down but cannot figure out how to turn it into a circuit?
    Please post what work you have so far. If you have absolutely no idea and expect somebody else to do your homework for you, you've come to the wrong place.
  4. mannycc
    Dec 11, 2010
    17
    Would suggest that you start with the ASM or flow chart to serve as your guide.
    Rgds.
  5. JoeJester
    Apr 26, 2005
    3,393
    1,211
    There are 118 results for elevator when searching this forum. I'm sure you can get idea's from from of them.
