wood lathe motor
jchal3
Joined Dec 13, 2009
78
Hello all, I inherited a wood lathe built in the 1930s. The motor is 220v 3phase, but the wires have all been disconnected and are not labeled. I know that the wires went through a switching mechanism that would run the motor in four different speeds. The motor has 9 wires. What I woukd like to do is find which wires are the high speed coils, then run those leads off an inverter so I can operate the machine on 220v single phase. I will attach a picture of the motor plate, the motor, and the switching mechanism. I am not really worried about the switching mechanism because I can control the speed with the inverter but maybe it will help answer the following question..... how to I find the high speed coil?
Any help would be appreciated.
It is almost like the motor is designed to run 480-220, and you just put 220 to the 480 coils to run in a slow speed.
Will have to upload pictures when im not on my phone
Dodgydave
Joined Jun 22, 2012
11,303
Looks like a 3 Phase motor, it may be wired like this
first job is to meter the wires out in Ohms to see which are joined or not.
jchal3
Joined Dec 13, 2009
78
The switch allows for four speeds.... is that possible to do by varying the connections of a two speed motor
jchal3
Joined Dec 13, 2009
78
I know it is wired in star. I found a wiring diagram but it is so faded it wouldnt show up on the camera. I could make out that it was drawn in 1930, and there were 4 star connections with l1 being tied together in all four stars. Ill try to get a better photo of it to post, or ill try to sketch it myself
Dodgydave
Joined Jun 22, 2012
11,303
Right so you need to meter out the common wire and then you can find the others , looks like they are all in star format.
jchal3
Joined Dec 13, 2009
78
I must have not been thinking last night. It should be three pairs and thecremaining three shoulx be the internal star....correct?
williamj
Joined Sep 3, 2009
180
It has been decades since I've seen drum controllers like those. I worked on overhead cranes and we had motors and controllers like those on some of our older cranes.
Dodgydave's coil drawing is spot on. Speed control was done through a series of resistor banks to drop the voltage for the slower speeds. There would be three sections, with three contacts per section, in the drum controller, one section per phase. Each section would feed voltage through a different resistance value, one value per contact, for each speed for a total of three speeds.
But like I said, it was a LONG time ago.
jchal3
Joined Dec 13, 2009
78
William, the actual schematic says it was drawn 6-6-30. So yeah, a while ago. So the switching mechanism I have actually changes the resistance? I kept thinking they were straight switches that changed the coils. So do you think hookingvthe motorvto a vfd and bypasding the switches would work?
Dodgydave
Joined Jun 22, 2012
11,303
okay, no laughing, here is the sketch as best I could tell from the wiring diagram.
Well if that's the drawing, looks like its got a DOL starter switch built in that works across two phases,
L1 goes to the Common rail, and L2 & L3 are put onto each pair of windings to set the speed,
Have you worked out the common wire yet?
jchal3
Joined Dec 13, 2009
78
No I havent yet. Right now none of the switches are hooked up. I plan to meter out l1 l2 and l3. Then im just going to use an inverter to control the speed and bypass thd switch. Does that sound like it will work?
