With E and H both contributing might be the reason for the basic observation of "fooling" the inverse square law. However, they do not talk of the contribution from each polarization mentioned.NEAR-FIELD: The region located less than one wavelength from the source is called the "Near-field". Here, the relationship between E and H becomes very complex, and it requires measurement of both E and H to determine the power density. Also, unlike the far-field where EM waves are usually characterized by a single polarization type (horizontal, vertical, circular, or elliptical), all four polarization types can be present in the near-field.
Since both the E field and the H field components of electromagnetic waves are absorbed by living tissue, and since the relationship between E and H is complicated in the near-field, we must measure both E and H when evaluating near-field hazards. This includes all low frequency sources, such as RF heat sealers.
We've been doing that since the days of Marconi ... polarization of the transmitting and receiving antennas.The intented target is to unbalance the E and H in the receiving end.The intented target is to unbalance the E and H in the receiving end.
Not going to happen. You will be irradiated with non-ionizing radiation from the E field as well as the H field. Both have OSHA standards for workers and public. Workers, meaning they had the training on the hazzards, has a higher threshold of uT exposure than the public.Also, this experiment avoids the radiative properties of RF radiation.
Beenthere,18. Near-Field Region. A region generally in close proximity to an antenna or other
radiating structure in which the electric and magnetic fields do not exhibit a plane-wave relationship, and the field strength does not decrease proportionally with the distance from the source but varies considerably from point to point. The near-field region is further subdivided into the reactive near field, which is closest to the radiating structure and contains most or nearly all of the stored energy, and the radiating near-field region where the radiating field predominates over the reactive field, but is not a plane wave and has complex field characteristics.
i have selected this as my this sem's project so need to complete in 3 months thts why a bit urgentPick one article from a reputable source. The first one I linked to, for example. Follow the procedure there.
It sounds like you are just beginning in this area. Why try to change what is known to work?
Yes, it is good to review prior art, but your first post indicates you have been doing that for months:
What is your sudden urgency?
John
0.1 mm spacing would only have a higher mutual inductance, as compared to the MIT transformer.This is not the conventional transformer with 0.1 mm spacing where little is lost in the form of RF.
RF, Radio Frequency, is both the H and the E Fields.Only a mere 3.3 Watts of the 150 W input was lost to RF radiation. They designed it to be this way so it would comply with FCC standards
So what is it? You said the lost 3.3 W to RF radiation and then stated they only radiated 3.3 W? I'm having a difficult time accepting your premise that only 3.3 W was radiated.In summary, that means they input 150 Watts to induce 60 Watts successfully to a 60 Watt light bulb 2 meters away, while radiating 3.3 Watts in the form of Radio Frequency.
Thread starter | Similar threads | Forum | Replies | Date |
M | witricity help regarding amplifiers | Analog & Mixed-Signal Design | 6 | |
Wireless Electricity Transfer (Witricity help) | General Electronics Chat | 62 | ||
witricity | General Electronics Chat | 13 | ||
K | witricity(wireless electricity | General Electronics Chat | 2 |
by Duane Benson
by Aaron Carman
by Duane Benson
