with transistors used as switches do they ever fail closed?
Discussion in 'General Electronics Chat' started by sdowney717, Oct 23, 2012.
  1. sdowney717
    Jul 18, 2012
    398
    14
    curious about that.
    Also how about using transistors as relays?
    What would be a transistor number that could easily handle 40 amps of DC power used as a switch?
    Should transistors replace relays? Or are mechanical relays better for switching on powerful loads.
  2. bertus
    Administrator
    Apr 5, 2008
    15,804
    2,389
    PackratKing likes this.
  3. PackratKing
    Jul 13, 2008
    850
    216
    Transistors, when in distress in a circuit, tend to melt, short out, or just plain detonate in some cases. I would have to say no, they cannot fail closed.
  4. kubeek
    Sep 20, 2005
    4,689
    806
    Compare them to mosftes for instance. These when abused - typically with overvoltage on the gate - tend to fail shorted. And if you´re in luck and the circuit is a single-ended switch it is not hard to end up with a permanently closed switch. In a push-pull configuration this usually either blows the fuse if present or the transistors melt enough after a while to become open circuit.
    It just depends on the basic topology of the circuit and on the actual design.
  5. Stuntman
    Mar 28, 2011
    189
    50
    I can tell you first hand that FETS can and do readily fail in a "closed" or "conductive" state.
  6. Dodgydave
    Jun 22, 2012
    5,155
    772
    I have replaced many a shorted out BU508D transistor with shorted C/E in a TV line output , so yes they do blow
  7. bertus
    Administrator
    Apr 5, 2008
    15,804
    2,389
    Yes, transistors and mosfets can go defective.
    A relay can also defective, the coil can burn or the contacts can melt together.
    Bertus
  8. Sensacell
    Jun 19, 2012
    1,183
    276
    My experience- semiconductors fail shorted more than they fail open.
  9. crutschow
    Mar 14, 2008
    13,501
    3,375
    I once say a TO-3 power transistor, which was part of a high power sonar transmitter, with a small hole burned in the top of the metal case directly over the emitter pin. The apparent cause of this was that the transistor originally shorted which, because of the high available current supply, caused the emitter pin wire bond to blow. This created an internal arc which then traveled to the top of the case (which was at the collector potential) and burned the hole until the arc extinguished. The transistor failure started as a short but definitely ended as an open.
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Cool story! I've never seen a TO-3 with a hole, but I have seen a few TO-220 with the entire plastic part blown off and just the metal tag and legs remaining.
