with 8051 send to LCD from .txt file
Discussion in 'Embedded Systems and Microcontrollers' started by karayel_kara, Dec 28, 2006.
  1. karayel_kara
    Dec 28, 2006
    Hi Friends,
    i am a new member and i have a question about 8051 project
    that is about writing lcd from text file but how will i not make it
    i expect any one has a idea this subject
    i waiting your suggestions or emaple codes
    among other things i use keil programer for 8051 with C
    best regard
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Generally, it is a good idea to get the specs on the LCD you plan to use. Then you can decide on the interface to use to go between the LCD and the 8051. After that, it's all programming.
  3. sci-3d
    Aug 22, 2006
    51
    Where .txt file stored is?
    I have only LCD Code with C but never read txt file and send to LCD.
    I think, you can store your text (not txt file) in EEPROM and then read it, finally send to LCD.
