Wiring two identical transformers
Discussion in 'General Electronics Chat' started by Dexter8181, Jan 23, 2009.
  1. Dexter8181
    Jan 21, 2009
    Hi all,
    I'm wondering if you can wire two seperate transformers with the same turn ratio together like the attachment. The primary sides are wired in series while the secondaries are wired in parallel. I'm sure this will work mathematically. What would happen if the impedance of the transformers were not exactly the same?
  2. italo
    Nov 20, 2005
    205
    don't worry abaout inpedance worry about phase
  3. Dexter8181
    Jan 21, 2009
    Well ok, just in general what would happen if the voltages produced on the secondary coils weren't exact?
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    It would work if you keep track of the start and ending of a coil.
    In the picture the Dots give each time the start of the coil.
    Greetings,
    Bertus
  5. Dexter8181
    Jan 21, 2009
    Would I still get 1V out if I didn't parrallel the secondaries and just left the other one open and tied my load to one? I know my power rating would be cut in half, but that's not an issue.
  6. KL7AJ
    Nov 4, 2008
    2,047
    294
    Absolutely. This method was used frequently for multi-line-voltage equipmnet back in the dark ages (when I was a "yute") :)
  7. Ardianwardhana
    Apr 2, 2009
    5
    Absolutely, you can't get what you desired when not parralleling the secs coz two prims weren't magnetically well coupled
  8. David Bridgen
    Feb 10, 2005
    278
    Your question relates to identical transformers. i.e. the number of turns on both primaries and both secondaries are equal. It follows that their secondary voltages will be equal.
