Wiring two A/C "circuits" in parallel for stage lighting
Discussion in 'The Projects Forum' started by danielson, Aug 16, 2012.
  1. danielson
    Aug 16, 2012
    My theatre has 1,000W lamps for our instruments we cannot use right now. Our dimmer packs which independently adjust single phase voltages to 4 different "channels" a piece can only handle around 700W per channel (fused).
    I was wondering if it was possible, and safe, to wire two of the channels together in parallel in order to be able to supply the needed current to power our 1,000W lamps?
  2. ErnieM
    Apr 24, 2011
    7,438
    1,626
    No. Do NOT wire two dimmers together.
    The best outcome to expect is to just blow the fuses.
  3. #12
    Nov 30, 2010
    16,704
    7,351
    More likely to work is to put 2 lamps in series. Less light, but it's any light at all, and it is dimmable.
    Another approch is to buy 500 watt lamps, one per channel.
    There just isn't an excellent answer to, "How to use the wrong equipment".
    strantor likes this.
