Wiring Multiple LEDs with ON/Off Switch - Question
Discussion in 'The Projects Forum' started by jbfatcat, May 6, 2015.
  1. jbfatcat
    May 6, 2015
    Hello all.
    I have a...hopefully...quick question on wiring my first LED project. Bare with me because I'm stupid.
    Without getting into the project details I'll just focus on the LEDs. Basically I have 20 total 5mm, 12v LEDs.
    10 blue and 10 red. Within that batch I have a some that flash, some don't and 2 switch between red/blue. I bought pre-wired LEDs. So they already have the resister and are ready to go.
    QUESTION ONE:
    I plan to use the wall outlet to power the LEDs. What I don't know is will 20 LEDs be too much for one 12v battery plug? How can I figure that out?
    QUESTION TWO:
    I have built in 2 push button style switches in this project. They could be "for looks" OR I could use one to actually turn the LEDs on. There are 2 "prongs" on this switch. In order to make it work I run the wire from the power into one "prong" and out the other side to the LEDs. So when pushed it's "ON" and when not pushed the power cuts...turning the LEDs off. Right?
    I guess I'll stop here for now.
    Thanks!
    jenny
  2. frpr666
    Feb 2, 2010
    37
    6
    You can connect your LEDs in series and in parallel way. (google.cz/search?q=resistor+in+series+and+parallel)
    Red LED has voltage drop about 1.8V. Blue LED has voltage drop about 3.3V. Do you have a multimeter at you hand?
    There are lot of pages about LEDs and resistors (http://www.evilmadscientist.com/2012/resistors-for-leds/)
  3. mcgyvr
    Oct 15, 2009
    4,784
    973
    They already have resistors.. So you simply wire them all in parallel with the power supply.
    Assuming they run at 20mA or less (very common) and you have 20 of them your power supply simply needs to be rated "higher" than 20 x 20 = 400mA..
  4. Søren
    Sep 2, 2006
    472
    28
    That sounds odd to me - care to clue us in?
    Please DO get into the project details - it will probably make it much easier to help you out.
    I also wonder why you use switches that just sits there?
    Is this for a stage prop or similar?
  5. mcgyvr
    Oct 15, 2009
    4,784
    973
    Sounds like he just has a 12VDC wallwart..
    And yes sounds like he is building a Police Space Ship :)
  6. Søren
    Sep 2, 2006
    472
    28
    Also sounds like he's named Jenny ;)
  7. mcgyvr
    Oct 15, 2009
    4,784
    973
    :D... I clearly don't have the time nor patience to read all the way to the bottom of a post
  8. jbfatcat
    May 6, 2015
    HA. Yes... "he"... is in fact a "she". :)
    I've actually built the holo chess table from Star Wars. AND. Awesomely enough I figured it out on my own. I didn't burn my house down and only shocked myself once.
    So as it stands today I have both sides wired to one on/off switch. I built it so that it runs on a re-chargable battery. That way I don't HAVE to be close to a wall outlet.
    Here's a link to the video. I don't have the final paint done NOR are the "keys" installed. So this is not totally finished, finished.
  9. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    I will help if I can, but I draw the line at getting naked.:eek:
    Max.
  10. Søren
    Sep 2, 2006
    472
    28
    Connecting the "dots"? ;)
  11. Søren
    Sep 2, 2006
    472
    28
    Where's the 3D play pieces?
    Whatever gets you off ;)
    Not bad. Did you sacrifice a Roomba or something like that for the housing?
    Please post a photo of the finished, finished prop when you get there :)
  12. jbfatcat
    May 6, 2015
    OH HA HA HA. You guys are SOOO funny. Don't lie. I know you're all sitting at home...nude...wiring electronics. ;-P
  13. jbfatcat
    May 6, 2015
    Nope nothing was sacrificed in the name of cool prop builds....THIS TIME!
    Actually what do you meaning by housing. I'll get some photos of the wiring and stuff. It's not pretty but it works.
  14. Søren
    Sep 2, 2006
    472
    28
    You didn't solder much, I can tell - at least not in your "Birthday suit".
    As a teen, I did solder a lot with bare legs (I had a marvelous reconstitution though, almost like Wolverine), but never without a pair of jeans these days - molten solder and bare thighs should be kept in separate places.
    If you try to get it off the skin with a flick of your fingers, it only spreads and it keeps liguid for a very long time (or at least it feels so when it's on your skin).
    Trust me, there are lots of better things to do nude than solder ;)
    Housing, cabinet, project enclosure/box, the thing that you wrap around the parts to make it look nice.
