I have a panel with a series of relay outputs on it (see photo).
I want to create a closed contact across 1 and 2 (see drawing) when relays R0 and R7 are closed.
R7 is currently disabled in the panel, I can re-enable this via the operating parameters.
I know this may seem a little simple to some, but my knowledge of electronics is not great, I assume I add a wire to #55 and then take this to my conact number #1 (on the sketch), and also take a wire from #40 on the panel and wire this into #2 (on the sketch)
would this work?
any advice would be greatly received.
would this work?
