Wiring help
Mikeee
Joined May 10, 2014
5
I have an old Washing Machine Motor 9 wires and want to use it to drive
a small Lathe
I need some help on how to wire it and be able to have different speeds
Would appreciate a bit of help
Mikeee
Joined May 10, 2014
5
Motor label SOLO. It came from a zanuzi washer dryer
Type 20584.024 AC
220/240V 50Hz. 300/1400 RPM
Wires no 1 Black. Windings
No 2 blank
No 3 yellow Speed sensor
No 4 yellow. Speed sensor
No 5 brown Windings. Then looped through plug to no 6
No 6 white. Windings then looped through plug to no 5
No 7. White. Windings
No 8 blue. Brushes
No 9.red. Brushes
No 10. Grey Windings
Hope this helps
Mikeee
Joined May 10, 2014
5
Thanks for your interest
The lathe Is a small model makers lathe " Myford "
Probably 60 / 70 years old which I reconditioned about 1973
It was flat leather belt drive which I converted to V belt
Driven by washing machine motor only 2 Wires came out of this motor
Earth was just Grounded to the motor and bench frame
MaxHeadRoom
Joined Jul 18, 2013
28,688
There are/were three basic types of motors used in W.M.'s Universal (brushed). Standard 1ph induction motor, and most recently the Fisher & paykel AC brushless outrunner.
It sounds as though you have one of the Universal motors, these were speed controlled by a Motorola TDA1085 IC.
Max.
Dodgydave
Joined Jun 22, 2012
11,303
i would use an ohm meter, measure the resistances of the windings, bet you have a tappeded winding possibly the black,grey,brown, and seperate white windings, if so connect the windings in series with the brushes, to make a universal motor, the tapped winding is for increased speed.
Mikeee
Joined May 10, 2014
5
Could you possibly do a quick sketch of how to wire it up
I am not to sure of what you mean by ( in series with windings )
Through the brush wires and then the windings ?
