Wiring Help 230v ac 1phase motor
Discussion in 'General Electronics Chat' started by shadowPDW, Jun 5, 2009.
  1. shadowPDW
    Jun 5, 2009
    Hello everyone, I have an aircompressor with a blown motor. Have a spare motor but its wired to spin the wrong direction. Is there any way to reverse spin on the singler phaze? Also can anyone help explain the wiring.
    There are 2 red and 2 black wires running out. They seem to be paired together. red and black both hooked to upper terminal marked L and other red and black both hooked to lower terminal marked 2. There are also 3 wires inside Black, yellow, green. They are plugged into the terminals as well.
    MOTOR SPECS
    General Electric AC Motor
    Model#5kc48ug640x
    1 phaze 60hz 1.5hp 230volt RMP 1725
    Thank you in advance
  2. mik3
    Feb 4, 2008
    4,846
    60
    Is there a starting capacitor?
