Wiring Four 110v 50A Step Down Xformers via 220v
gatekeeperamps
Joined Sep 17, 2012
7
I am building a 200AMP Power Supply that will have about a 12-16v Float. I have everything down pat after the Primary of the Transformers but I have never wired up Transformers with 220v Before. That is my problem. If I was using 110v then I would just put the hot to all the positives of the transformers and Ground all the Neg.
I know this is a little different.
Again, These are 110v Step Down Transformers. 110v - 12v w/ 12-16v Float.
I have already went to the trouble of taking time to draw out the full diagram with leaving the wiring of the primary windings of all 4 transformers blank hoping that you could download the picture, open it in Paint Brush or whatever picture program you use and draw it in for me. LOL. That would be a blessing.
