Wiring Diagram Help for OP AMP please
Discussion in 'The Projects Forum' started by lostintranslation, Nov 23, 2013.
  1. lostintranslation
    Nov 6, 2013
    37
    using an LED that bleeds a little from the capacitors I'm trying to read, only bleeds .1 volt a second or so, but I was trying to get it to no bleed. I have an OP AMP for higher impedance to the LED but I could use help translating the wiring diagram and circuit diagram. Near as I can tell, this is how it should be wired up. Any help translating would be appreciated. As always thanks in advance.
  2. lostintranslation
    Nov 6, 2013
    37
    well, it reads the 9v battery and not the cap this way. on the bright side there are only finite combinations left. lol
