Wiring audio jack
Discussion in 'General Electronics Chat' started by jarwulf, Mar 16, 2014.
  1. jarwulf
    Jul 7, 2013
    60
    Hi, I'm having some issues wiring a 4 conductor audio jack.
    This is the current configuration. It actually seems to have worked when wiring a female audio connector. However for the jack I have now the speaker works fine but the mic/transmitter does not. Depending on how I switch the nonground wires the speaker works or doesn't and the mic/transmitter doesn't work at all. Sometimes I can use the speaker as a microphone/transmitter as well. I would guess that the problem is the common connection to the ground but what would be the ideal connection then?
  2. shteii01
    Feb 19, 2010
    3,500
    511
    lol
    the mic does not work because you are plugging it into port that is designed to output, not input
  3. shteii01
    Feb 19, 2010
    3,500
    511
    Take a look at computer sound card.
    The port for mic and port for speaker are two SEPARATE ports.
  4. jarwulf
    Jul 7, 2013
    60
    The port I'm plugging the jack into carries both audio data out to a speaker and takes in audio data from a transmitter. Weird, but I didn't design it. Both the Speaker and transmitter have worked before with different jacks I just am trying to figure out how to make it work this time.
  5. shteii01
    Feb 19, 2010
    3,500
    511
    Hm, ok, sounds like Apple product. Good luck.
  6. jarwulf
    Jul 7, 2013
    60
    So I rewired based on iphone plugs with 4th ring mic third ring ground and the tip as speaker. Mic works now. Unfortunately the speaker is sounding fainter now too. I suppose the other unused audio channel is sucking up power. Somehow before I had a much stronger audio signal. What to do....hmmm.
  7. GRNDPNDR
    Member
    Mar 1, 2012
    449
    7
    I could be mistaken, but if it's a TRRS connector, then there are two separate grounds.
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    the connector on the sound board is for a headset, mic and speaker. the first diagram is close, try reversing the mic and speaker leads.
    jarwulf likes this.
  9. jarwulf
    Jul 7, 2013
    60
    Thanks, that is how I have it now. I want to boost the anemic speaker output somehow though. It was decent in some connections before but now for some reason is very low. Would combining the two speaker channels like this work?
  10. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    This might give some help: http://pinouts.ru/
