Wiring A Switch
Discussion in 'The Projects Forum' started by mapleman555, Apr 2, 2015.
Thread Status:
Not open for further replies.
  1. mapleman555
    Dec 15, 2014
    56
  2. Reloadron
    Jan 15, 2015
    1,055
    275
    Sounds like you have a 2 Pole 5 Position rotary switch. This means the switch has two Commons which depending on position can connect to any of 5 positions (contacts). Using 1/2 the switch and resistors as you mention it would look like this:
    That what you are looking for?
    Ron
  3. mapleman555
    Dec 15, 2014
    56
    Yes, I think so. I'll have to give it a try, thanks.
  4. Reloadron
    Jan 15, 2015
    1,055
    275
    Really there are a dozen ways to wire a switch like this depending on the application. I only drew up a quickie single example. There are many things to consider too, like circuit current and voltages as compared to the switch specifications.
    Ron
  5. mapleman555
    Dec 15, 2014
    56
    Well the main thing I want to use it for is making electric guitar pedals, like a distortion stomp box. Changing the values of the components of the pedals can change the sound you get so I want to do some testing to see what works for me.
  6. Reloadron
    Jan 15, 2015
    1,055
    275
    Cool, then you want something along the lines of what I posted.
    Ron
  7. Reloadron
    Jan 15, 2015
    1,055
    275
    Here is another example of selecting 1 of 5 components. Resistors are shown but they could be capacitors.
    Ron
  8. mapleman555
    Dec 15, 2014
    56
    Thanks again.
Thread Status:
