Attached should be a PDF file detailing an 8 pin SDPT relay. I will be using 12v dc to power the coil and hope to use the relay to switch 220 VAC. I'm a novice at this and need help as to which connections I use to connect the AC supply and which connection delivers the switched power. In case the PDF file fails to load the relay is Maplin Item N06AW
