Wiring a small 2 speed AC motor
Discussion in 'The Projects Forum' started by Gdrumm, Jul 10, 2011.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    I should know this....
    How do I wire up a small 2 speed AC fan motor?
    It has three wires, 1 Red, 1 Black, 1 White.
    For low speed?
    For high speed?
    Thanks,
    Gary
  2. iONic
    Nov 16, 2007
    1,422
    68
    How do you know that it is a two-speed fan?
  3. Gdrumm
    Aug 29, 2008
    684
    36
    The switch to which it was previously wired had Low and High.
    It has been disconnected from the switch, and from the 110v
    The switch also has 3 wires, 1 red, 1 white, and 1 brown, which have been cut.
    Thanks,
    Gary
  4. iONic
    Nov 16, 2007
    1,422
    68
    Well, the switch and fan that I have offers a twist, so I don't think if the fail-safe solution.
    From 110VAC there is Black(HOT) and White(GND). The black goes to the black of my switch, I'll call it SB1, then from the switch SB2 it goes to the black of the fan. The white from the 110VAC goes directly to the white of the fan. The red from the switch goes to the red of the fan. My switch is a rotary three position switch, Off - High - Low. With AC often the only difference between the Low and High speed is a diode which effectively cuts the avg. voltage in half. I had to remove the diode from my stoves overhead switch so that I could replace the halogen lamps with fluorescent ones. Most fluorescent light do not like varied voltages.
    So, bottom line, I can not really give you the definitive answer. I can only assume that the whit on the switch is the same as one of the black wires on my switch.
  5. Kermit2
    Feb 5, 2010
    3,849
    965
    The AC wiring is slightly different from most DC wiring schemes
    The BLACK wire is the HOT wire
    The white wire is the Neutral wire, and depending on your situation either one could severely shock you.
    The BLACK wire is HOT. When it comes to AC try to remember. BLACK is DEADLY
  6. iONic
    Nov 16, 2007
    1,422
    68
    Is that why my electric bill is so low and nothing seems to work! I knew that!
    ...Open mouth and insert both feet here iONic.
    I'm changing my post above so that someone else does not read my post and then not your post. Thanks for the insight.
