Wiring a Shure Modular Cable
Discussion in 'The Projects Forum' started by rachshot65, Oct 25, 2008.
  1. rachshot65
    Oct 25, 2008
    7
  2. bertus
    Administrator
    Apr 5, 2008
    15,800
    2,386
  3. rachshot65
    Oct 25, 2008
    7
    Thanks the cables only twin core so I assume I connect the silver coloured cable thingy (sorry cant think of a better word) to ground ?
  4. bertus
    Administrator
    Apr 5, 2008
    15,800
    2,386
    Yes , the shielding is ground , the other wires (red and white) are for the left and right signal.
    Greetings,
    Bertus
  5. rachshot65
    Oct 25, 2008
    7
    The parts came today. How do I tell which is left and which is right? Theres just three tabs. One is longer than the rest and I assume ground but the other two are next to each other. One is coloured gold if that helps.
  6. bertus
    Administrator
    Apr 5, 2008
    15,800
    2,386
    To see what is connected, you can take off the caps and put them together.
    Now you can measure with a multmeter in resistance measurement what is near 0 ohm.
    These parts are the signal path.
    The shield should be connected to the long part in the plug.
    You could also see a lot in the wiki page i gave you.
    Greetings,
    Bertus
