wiring a PLC
Discussion in 'The Projects Forum' started by Bigcountry, Sep 19, 2010.
  1. Bigcountry
    Thread Starter Active Member
    Jul 4, 2008
    71
    I got this Click PLC and I was wondering if I could hook up different voltages types up to it. I saw it on the support tools on the Click web site. I am just double checking to make sure. I need to do control 220 VAC and 24 VDC.
    thanks for any help or information that I can use.
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    Sorry to sound ignorant but what's a "Click PLC"?
  3. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  4. Bigcountry
    Jul 4, 2008
    71
    Click PLC is a PLC from Koyo.
    http://www.aboutplcs.com/click/
    My concern is the input and outputs. I read this manual online and I am assuming that I can run and control different voltages which is only three different voltages.
    http://www.automationdirect.com/static/manuals/c0userm/ch3.pdf
    On page 4 of this manual it says that there is 4 discrete inputs and 4 discrete outputs. Again I am assuming but I am pretty sure I can control the three different voltages that I need to control. I probably would have been better off to use everything that has the same voltage but I am not that fortunate enough to have all the same voltages. I have to control a fan solenoid valves.
    I should put a breaker in the line to help with safety issues that may arise.
    thanks for any help you can provide.
  5. marshallf3
    Jul 26, 2010
    2,358
    201
    Oh, just a programmable logic controller, the "Click" threw me off.
  6. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    So, what's your model #
