Wiring a FD3000-030 fan motor
Discussion in 'General Electronics Chat' started by canelshop, Jun 23, 2014.
  1. canelshop
    Jun 21, 2014
    I am trying to revive a dehumidifier with a bad fan motor. The old motor has a 3 wire connection while the one I want to use has 5 wires(black,white,blue,yellow[low],red[high]. Not sure how to make the change. Can anyone tell me how this motor should be hooked up?
    Fan motor from dehunidifier.JPG This attachment shows the diagram on the motor label.
  2. shteii01
    Feb 19, 2010
    3,516
    515
    Broken Motor
    Name
    Model
    Connection instruction
    Replacement Motor
    Name
    Model
  3. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    This appears to be a 3 speed motor.
    Max.
  4. canelshop
    Jun 21, 2014
    Bad motor is a Oh Sung 4681a20040 and is 1.4 amp with three wire harness
    NEW MOTOR: Zhong Shan Broad-Ocean YDK-020l41503-02 with also a #FD3000-030
    1250/1100rpm. The harness has 4 wires and then a separate black wire.
  5. canelshop
    Jun 21, 2014
    Maxheadroom; Thanks for the attachment. It is a two speed motor and it must need something else to run it. It works fine plugged into the old units control board. Seems like if I move the motor over to new dehumidifier, I need to also use part the the old control board. Any thoughts?
    Old motor from dehumidifier.jpg old motor
  6. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Apply power briefly to Black and red, it should run as a split phase motor, your original one appears to be shaded pole motor.
    Max.
