Wiring a Bosch Relay as an OR Logic Gate
Discussion in 'General Electronics Chat' started by Xaxas, Nov 14, 2013.
Thread Status:
Not open for further replies.
  1. Xaxas
    Nov 14, 2013
    Hello guys! I'm adding LEDs to the interior of my car, it comes in an RDG strip and I plan to wire them to the Dome welcome lights AND to the headlights so the also work as ambient lights in the night, I know which fuses to tap BUT I need to wire a Bosch Relay to work as an or gate, this is what I have in mind but I'm not sure (I'm a noob)
    30: Led Strip
    85: Ground (derp)
    86: Headlight fuse
    87: Constant 12v
    87a: Dome Light
    This way, when the headlights are ON the coil is activated and the gate lowers to 87 which is constant 12v, so the LEDs will always be ON, else the gate will be on 87a and will only power the LEDs when the Dome Lights are ON (doors open)
    So what do you think, will this work?
    P.S: I have 5 Bosch Relays, but my life would be so much easier if I could only use one, thanks.
  2. passitherm
    Nov 14, 2013
    Well you are thinking very nice, you do it. Its a very good plan.
  3. Xaxas
    Nov 14, 2013
    Thanks! However, I want to make sure it WILL work, I don't want to blow up a $33 LED strip especially how difficult it was for me to get it (I don;t live in the US)
    This is a diagram of how the relay works just in case
    http://www.coolcatcorp.com/faqs/relay1.jpg
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics.
    The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    bertus
Thread Status:
