Wiring a 12V DC fan in an AC ballast enclosure
Discussion in 'The Projects Forum' started by miston, Apr 3, 2006.
  1. miston
    Apr 3, 2006
    I will be building a wooden enclosure for a single 13watt power compact flourescent bulb that will be placed flush against the back of my aquarium. I purchased a kit with a ballast and reflector. Since it will be flush against the aquarium glass I will need to install a fan to help with the heat. Other that have done the same type project also recommended a fan.
    I am going for a clean, professional looking installation, and I only want ONE AC cord coming from the enclosure.
    The fan I will be using is a low decibel computer fan (Artic Cool) which runs on 12V DC @ 0.12 amps.
    How would I wire this? Where should I purchase the necessary parts? Radio Shack? Online?
    thanks in advance for any help and suggestions!
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  3. n9352527
    Oct 14, 2005
    1,198
    ...or a _big_ resistor in series...
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Hmmm... any idea what the impedence of the ballast is? :D
    (Don't forget the need for rectification if the "big resistor" option is used. The fan given is DC.)
