Wiring 6 wire 3-spd exhaust blower to 120V AC
Discussion in 'General Electronics Chat' started by Mikeysp, May 18, 2016.
  1. Mikeysp
    May 11, 2016
    12
    The fan is off a over range microwave. See picture below.
    The yellow label on the motor caused me some confusion.
    1. I am trying to wire the fan to run high speed and plug into a standard 120V/60Hz AC Outlet with a simple on/off switch. The fan will not be going back into a microwave so I will be cutting off the plug connector. Can I wire it directly to a 120V AC plug, or do I need some special power supply between the 120V outlet and the fan? If you look at the label on the motor, it has "input: 210/125/100". What does this mean? Input in my mind is 120V AC, so I am a bit confused.
    2. I have added a pic of a capacitor that I have on hand. The mF do not match. Will my capacitor work fine, or do I need to get another capacitor?
    3. What is the rectangle with the letters T/P on the diagram?
    5. How I was thinking it should be wired, before the yellow data label confused me:
    Neutral to white wire.
    Hot through a toggle switch to the blue wire for high speed operation.
    Orange and Red to the capacitor.
    Violet and Yellow not used.
    Thank you,
    -Mike
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    Looks correct, T/P temperature sensor, Thermally Protected.?.
    Cap should not be super critical.
    Max.
  3. JWHassler
    Member
    Sep 25, 2013
    204
    34
    Your idea seems correct, since the wires are marked H,M, and L
  4. Mikeysp
    May 11, 2016
    12
    Thanks for your response Max.
    I will just eliminate the temperature sensor, unless, of course, it is an internal item on the motor.
  5. Mikeysp
    May 11, 2016
    12
    Does anyone know what that 210/125/100 on the yellow label refers to?
  6. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    The thermal sensor is usually embedded in the winding's.
    I am assuming that the impedance is such that it will tolerate a wide voltage range.
    Max.
  7. #12
    Nov 30, 2010
    16,671
    7,319
    Looks like watts from here.
  8. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    Probably more accurate a reason.
    Max.
    #12 likes this.
  9. Mikeysp
    May 11, 2016
    12
    Of course. Thank you men! Have a good evening!
