Wiring 56j 110/220 ao smith/Hayward pool motor
Discussion in 'General Electronics Chat' started by etbrown4, Jul 27, 2011.
  1. etbrown4
    Jul 27, 2011
    I have 3 loose wires which I believe go to the white contact block, where the voltage is selected.
    I have a blue, a purple and a white. The blue comes from some type of round contact or switch, the other two seem to be winding leads.
    The terminal choices are L1, L2, and A.
    Does anyone know which goes where. hopefully having worked on a similar motor to mine?
  2. KMoffett
    Dec 19, 2007
    2,586
    234
    56J is just the frame style. What's the voltage and HP on the motor label? Have you contacted the company?
    A little Google'ing:http://www.poolcenter.com/pumps.htm Page 3 might help.
    Ken
  3. etbrown4
    Jul 27, 2011
    std ao smith motor on Hayward Super Pump II 1.5hp
  4. KMoffett
    Dec 19, 2007
    2,586
    234
    http://www.hayward-pool.com/pdf/manuals/Manual258.pdf
    Interesting...no wire connection info in the manual. Perhaps they don't want you wiring it it you're not a qualified electrician. I was going to ask again..."have you contacted the company?"...but: http://www.haywardnet.com/contactus/ No email addresses or phone numbers! Even though the title on their "contact" page is "We're Here for You" :(
    Since pool electrical wiring is a "life safety" issue, I would advise getting an electrician.
    Ken
