Hi everyone,
I am using a very low diameter wires to solder a pic 12f629.
I think it may cause theprogramming failure i am experiencing due to high resistance (maybe)
What do u pro's recommend for soldering on a bread board (diameter, brand)?
I am using a sop to dip 8 pin convertor and then soldering on the bread board, from the breadboard i put dip pins which connects directly to a pickit 3.
Meaning pickit is connected directly to the bread board without further wires.
Thaught that maybe lowering resistance of cable by getting a wider diameter will solve the issue..
