Wires Connected to Capacitors
Discussion in 'Homework Help' started by Healthycola, Mar 8, 2010.
  1. Healthycola
    Mar 8, 2010
    Hi, I'm new to the forum so I apologize if I'm not following some sort of rule or something.
    In my lab, I have a capacitor (measured capacitance is approx 138pF). Now I had to measure the capacitance of the wires alone (approx. 41pF). The calculated capacitance should be around 84pF. Now, my question is, is the wire's capacitance in PARALLEL with the capacitor? Shouldn't it be in series?
    Thanks!
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The electrostatic field lines between the elemental static charges on the connecting wires are effectively in parallel with the field lines between the charges on the capacitor plates. So the overall effect is that the lead and plate capacitances add - as for parallel connection of capacitors.
