Wireless TX/RX
Discussion in 'Wireless & RF Design' started by 19900110, Nov 3, 2011.
  1. 19900110
    May 20, 2009
    5
    Hello All,
    I am required to make a simple remote control servo. The TX/RX pair which I use is DataBridge SE1200A. (http://www.starmanelectric.com/Products/DataBridgeSMD/tabid/82/Default.aspx) This TX/RX basically provide the function of transferring data from local PC to a remote receiver. Then I may connect the receiver with a PIC to translate my signal to a PWM signal to drive the Servo motor. Is there any suggesting to a similar Tx/Rx pair which is suitable in this specific design? Or any ideas/suggesting about it? Much appreciated, Thank you all in advance. I'd like to provide you with further info if needed.
  2. radiohead
    May 28, 2009
    474
    31
  3. 19900110
    May 20, 2009
    5
    Thank you for your advice.
