I do not know if any of you have heard of a crystal radio: (http://en.wikipedia.org/wiki/Crystal_radio), but in a nutshell it uses the very radio waves in the air as its source of power, no outlet or batteries required. From what I understand from the reading, the radio waves received are converted into AC current, which is then converted in DC current. My question is, is the antenna designed only to receive certain frequencies to receive and turn into power, or does it pick up any radio wave it comes into contact to and turn it into power and display the preferred frequency through the earphones? Also am I correct in the assumption that it is AC current that is generated from these waves?
Thanks!!
David
Thanks!!
David
