Wireless square wave pulse transfer
Discussion in 'The Projects Forum' started by ash.online6, Oct 16, 2013.
  1. ash.online6
    Jul 20, 2013
    6
    Hey guys i want help in designing a circuit to transfer square wave pulse fed on transmitting end through a frequency generator and get it on receiving end and check it on an oscilloscope.
    range should be about 10m and transfer is only one way
    other specifications are as follows:
    Square wave signal output from npn transistor with internal 2.7kΩ pull up resistor, dc coupled to supply.
    8-25V dc
    12mA maximum current consumption
    0-15KHz frequency range
    i would also require source code along with schematic.....plz help
  2. GopherT
    Nov 23, 2012
    6,340
    4,094
    Check eBay for a simple 315 MHz transmitter / receiver pair. Usually about $5.
  3. ash.online6
    Jul 20, 2013
    6
    how to proceed after i got the modules...
    i guess that the signal cannot be directly fed to the transmitter.....it might require modulation
  4. GopherT
    Nov 23, 2012
    6,340
    4,094
    The cute little devices take care of all that. Just feed the 0 or 5 volt signal. The receiver will receive, demodulates and output the high/low as you input to the transmitter module. Very, very easy. Sometimes you have to 'tune' the transmitter or receiver by pulling the coil apart slightly or pressing together. Just connect a small audio amp (lm 386) to the receiver with a speaker and feed a 400 hz signal to the transmitter. adjust coils as needed to tune if needed. Use the same technique to adjust antennas and maximize tranmission distance.
    Then disconnect the lm386 or similar and use with your application. If you want to get even simpler and avoid the audio amp and speaker, use an LED flashing at 1 to 10 hz instead of the audio amp. Be sure to add an appropriate current limiting resistor (220 to 330 ohms for a red LED).
    Looks like the little module pairs are only $1.50 from china (including shipping if you can wait 3 to 5 weeks).
    ash.online6 likes this.
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
  6. ash.online6
    Jul 20, 2013
    6
  7. ash.online6
    Jul 20, 2013
    6
    what if the duty cycle is not 50:50?:confused:
  8. Shagas
    May 13, 2013
    802
    74
  9. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Yeah, 5 pairs of TX/RX modules for a total of US $6.14 is pretty good.
