Wireless Sensor Network using ZigBee Protocol
Discussion in 'Embedded Systems and Microcontrollers' started by schnnegi, Jan 7, 2009.
  1. schnnegi
    Sep 24, 2008
    9
    Hi friends I am Sachin Negi.I am Doing my MTech project on ZigBee protocol using microchip PICDEMZ kit + PIC18LF4620 controller.
    I have to give different sensor's output to receiver side.Three ZigBee kits are programmed as transmitter and one as a receiver.
    I am unable to establish addressing b/w them.
    How one can address these devices in a ZigBee Network.(Means how can one understood that this node data is coming fron this particular device)
    Thanks friends to read this!
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    Have you looked at Microchip's documentation for their Zigbee stack?
  3. Alberto
    Nov 7, 2008
    169
    36
    You must downlod datasheet from texas instruments and very likely texas should also have some software tool for setting the zigbee device address and general setup.
    Another way is that along with the string you send out also the address so that only the receiver with that address name will respond.
    Alberto
  4. nanovate
    May 7, 2007
    665
  5. Alberto
    Nov 7, 2008
    169
    36
  6. nanovate
    May 7, 2007
    665
    If my platform is from Microchip why would I look at Texas Instruments for information on how to set-up my platform. Compliant does not equal identical.
    Does Texas Instruments develop Zigbee software for Microchip?
  7. schnnegi
    Sep 24, 2008
    9
    Thanks nanovate and Alberto.
    Friends I am using Microchip Stack v1.0-3.8
    Also using microchip RF daughter card. here using stack AN965.
    I changed the MSB of MAC address in zigbee.def file but I am unable to receive different short addresses for these RFDs.
  8. schnnegi
    Sep 24, 2008
    9
    yes I looked at those user guides
  9. schnnegi
    Sep 24, 2008
    9
