Wireless powered rotor electric motor project
Discussion in 'The Projects Forum' started by Jason27, Dec 1, 2015.
  1. Jason27
    Nov 15, 2015
    32
    Hi guys, wondering if I could get help to make this motor electrics more efficient/powerful. I've made it and it works but I'm sure it can be enhanced to be better. Any help appricated. Thanks image.jpeg image.jpeg
  2. Jason27
    Nov 15, 2015
    32
    anyone?
  3. wayneh
    Sep 9, 2010
    12,361
    3,220
    How do you define better? Have you made measurements and identified any losses?
    One thing you might consider is the air gap between rotor and stator. The smaller the better but of course you need mechanical precision to avoid contact.
  4. Jason27
    Nov 15, 2015
    32
    Thanks for your interest, well I'm not a electrical engineer by any means, so by better I was hoping to see if the circuit I'm using is the one to use.if it's ok,not sure if I'm using the correct resistors,transistors etc.
    I haven't made any measurements as I don't really have the expertise or equipment, which makes it hard yes! I want to make better coils as the ones I'm using were to see if it works. But again,not sure on wire size or how many winds I should use. Is there a frequency I should be aiming for? And what I should be using to obtain this.
    I was after information or ideas on what I should be doing to improve this system by someone with more knowledge on this subject like yourself.
    Thanks Wayneh
  5. kubeek
    Sep 20, 2005
    4,686
    805
    You see, in the first post you ask how to make this more powerful. I have a hard time decoding what THIS might actually be, how it is supposed to operate and what should it actually do. You need to do a lot more explaining if you want some help.
  6. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,676
    1,294
    Why is there a capacitor in series with full wave rectified AC and an inductor?
    ak
  7. wayneh
    Sep 9, 2010
    12,361
    3,220
    Current limiting?
    But anyway, a circuit description and a statement of the goals would be nice before we can make it "better".
  8. Jason27
    Nov 15, 2015
    32
    Is there pictures there for you to look at?It's not that hard to work out mate, Motor!!
  9. Jason27
    Nov 15, 2015
    32
    Sure,I'll do my best. So I'm using the H-bridge controlled by the hall sensor to change polarity on the stator electromagnet to oppose the rotor for motion. The bottom part of the circuit is switching to give Ac for the wireless transmission to work then rectified to feed power to the rotor electromagnet. Goal is to get it to work correctly. As its gone from a simple idea in my head to a working model that I can't find anywhere else. So would love to make a decent prototype if we can sort it out.
    Thoughts?
  10. Dodgydave
    Jun 22, 2012
    5,127
    766
    I don't understand why you're using 12v dc to make an hf oscillator pulsing a pushpull transformer, then converting the Ac back to Dc to feed a coil?
    Is the transformer a wireless connection pickup, like a wireless charger?
    Jason27 likes this.
  11. Jason27
    Nov 15, 2015
    32
    Yes, exactly. Is this the way to go or is there a better circuit available? If this ones ok! Can I make it more powerful to make my electromagnet stronger?
    Dodgydave likes this.
  12. Dodgydave
    Jun 22, 2012
    5,127
    766
    Still dont get why you want a Wireless motor,?
    surely when you connect power to it its going to move from its position and what psu is feeding the stator a battery or a dc psu?
  13. Jason27
    Nov 15, 2015
    32
    Well Dave I thought like a conventional induction motor
    im using wireless for the rotor so there's no brushes,friction,magnets like a coventional motor. I'm using a battery atm for the whole thing. What do you think I should use.
    And thank for your interest too Dodgydave. As I've said I'm really not that good at electrics. But I'll get there.
  14. Dodgydave
    Jun 22, 2012
    5,127
    766
    You're better off designing an ac motor, with a rotating field, like a three phase motor, wireless power is too wasteful, stick to conventional brushes.
  15. Jason27
    Nov 15, 2015
    32
    Ok, trying
    Ok, trying to learn here, but isn't that how a Ac induction motor works? Wireless powered to induct the rotor?
    So you think(know) there's to much loss here?
  16. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    Wireless sort of implies radio, the induction motor is by magnetic induction, an induction motor at switch on is a transformer with a shorted turn secondary, hence the high initial current, as the rotor turns and the slip frequency decreases, the difference between the rotating stator field and the rotor field, so does the current.
    Max.
    Jason27 likes this.
  17. Dodgydave
    Jun 22, 2012
    5,127
    766
    Its not wireless, it directly enerises the coils and creates a rotating field, and the rotor follows this magnetic field,
    Or if its a universal motor it creates a field in the stator, and an opposite field in the rotor which keeps alternating as it rotates due to the brushes.
  18. Jason27
    Nov 15, 2015
    32
    Ok, thanks MaxHeadRoom, Dodgydave. Dave as you said with the universal motor I guess that's what I'm trying to do here. I'm making another now with more poles on both stator/rotor. But my idea was to eliminate brushes due to wear,friction,limiting RPM & places the motor can be used like confined spaces due to dust from brushes. I also thought I could make it more powerful by eleminating magnets and using stronger electromagnets! I thought it was a good idea. Looks like it's not! But still,it was worth a shot.
  19. MaxHeadRoom
    Jul 18, 2013
    10,813
    2,491
    You may be better off to make a BLDC motor, these are gradually replacing both induction and DC brushed motors, an interesting concept is the outrunner, such as used in RC and the Fisher-Paykel washine machine motor.
    http://www.directdrivemotors.com/
    Max.
  20. Jason27
    Nov 15, 2015
    32
    Funny you say that max, that's where all this started for me. That actual Fisher-Paykel motor. Thought I could improve on that by eleminating the magnets with more powerful electromagnets with no brushes. Have defentaly appreciated the input from all you guys here. But still. If you think of something I can try to improve this motor or the circuit I have would be great. Thanks
